Kitchen Knives Set - Pic Heavy
Back in June of 2015 a friend of mine commissioned me to make some kitchen knives for her to gift to a friend of hers. Well I finally finished them a couple of days before Christmas. Could be a slow poke record, I'll have to check. Anyway, we agreed on three knives and I thought these would be the way to go. And since I couldn't just hand her a brown paper bag full of sharp knives I made her the box too. Details below. Comments and criticism welcomed.
Box
Pine with black fabric covered foam inserts with finger reliefs for extracting the knives. I didn't have time to make anything fancier but it would have been a waste anyhow. The knives are going to live in a knife block so the box will just get stored in a closet somewhere.
Knives
Blade Steel: AEB_L (Uncle Aldo). Approximately 61.5–-62Rc.
Pins and Spacers: 316SS
Handles: Black Corian and Stabilized Curly Hawaiian Koa (Koa from Mark at Burl Source)
The blades are all radiused at the spines and choils. Blade bevels are finished to 600X to aid in food separation. Handles are sanded to 2500X. The Koa is finished with TruOil. The 253mm Gyuto and 210mm Western Deba balance at the front of the bolster and have generous height for knuckle clearance. Naturally, the 140mm petty is handle biased due to the smaller blade. The Gyuto has a long constant taper to the spine and ground very thin. The Deba is left full thickness much farther down the spine to leave weight and strength for chopping tasks. It's ground fairly thin as well but left a bit thicker behind the edge for a more durable cutting edge. The petty is somewhere in between. The cutting edges on all three models have a nice straight section for completing the cut.
Photos
Man, those are really nice!!!!! Cool way to use Corian without having to contend with so much extra weight in the handle. Just a thought. have you thought about maybe using a hidden pin at the front of the wooden part of the handle and going for a traditionally spaced 3 rivet pattern?
There is a hidden pin in each handle under the koa. I did not think to lay it out the way you suggest. A few major details changed on the knife while I was working on them. In the end, they are what they are. The recipient was very happy. As long as that is the case I'm happy too.
Thank you everybody for your kind remarks.
Cool. That is one well secured handle!!!! Nice clean job of going up the two parts and the spacers. What is the contrasting strip on the top of the box? It looks good. Pretty elegant for a "basic pine box" ya know? :thumbup:
I had two challenges with the box. One was how to add my logo or makers mark. All I had available was my leather stamp and that doesn't do wood that well. The other issue was that the top and bottom of the box was the same size. If someone wasn't paying attention and opened the box upside down by mistake we'd have a problem. So the solution I chose in the time I had was to simply add a leather strip down the center of the lid. This way I could add my mark and people would know which side was up.
Marc;
Very nice work. I just completed my first set of kitchen knives this Christmas, and suffice it to say they pale in comparison. You definitely inspire me to keep improving.
