I would like youe advice on the best klingspor belt the model number if you can and best all around grit to shape and work down before switching grits. I am using only stainless some 440 c but for the most part im making CPM154 blades from 1.5 inch flat ground stock. I have used the LS 300 series belts in the Jflex series and they are i believe a zirconia belt not bad but but dont last long. Then ive also used the CS411 belt i think they are a semi ceramic belt ive used lots of 60 and 80 grit and they are ok but, I think there has to be better. What im looking at getting are the CS631XF belt made by klingspor or the[ CS910y act ] i believe are both ceramic belts designed for stainless grinding. Also if i was to order 10 at a time what is the best grit to start grinding 60 or 80 . I know a 36 or 40grit will remove stock faster but i have to buy 10 at a time so I have been starting with 60 should i try a lower grit or just get a few lower grit ? Thanks kellyw
