I have recently been experimenting with sharpening systems so ill add some of my thoughts, keep in mind I haven't used the KME, only the edge pro type system, and a wicked edge go. From my use and research I have concluded that if you want to sharpen high end knives without any fear and create even bevels with the highest precision then go with the wicked edge. If you want maximum versatility then go with edge pro or something similar. The KME is not as precise and clean as the wicked edge and not as versatile as the edge pro platform.
The KME is perfect for someone wanting to get a polished razor edge with little effort, and someone who wants the least amount of complications, additional purchases, and doesn't care about every little detail. If you only want to use the angle guide marks and you're not ocd about getting exact angles with an angle cube, the sharpener has some wobble and is probably the hardest to set consistent exact angles. Since you flip the knife and keep the arm set to one angle something like a FFG will be sharpened unevenly unless clamped perfectly straight. Many people have reported scratching their knives up with the KME because the diamond stones launch little pieces during use onto the side of the blade. Some say this goes away after the stones break in, some say doesn't. Regardless there is a concern with high end knives, you should tape everything up just like you would on the edge pro since the slurry can scratch the blade.
The Wicked Edge is for someone who wants professional level precision and repeatability that will look sexy laying on a table. The system is very well build and stable and with an angle cube you can get exact, even bevels on both sides of the knife. For FFG blades you can either makes sure you get the blade clamped straight using an angle cube or you can just account for the difference and adjust each arm independently and exactly. The whole system lends itself to be very repeatable if you record your exact setting with their grit guide. The stones do require break in but only to get a cleaner scratch pattern, haven't heard of scratching issues. I would still tape expensive knives on the clamping point but this system is the least likely to scratch any knife. The only downside to the WE is not being able to bring the stone right up to the plunge unless you modify the handles with a dremel or grind a sharpening notch in some knives like Spyderco.
The KME has an advantage if you plan to use water-stone because compensating for stone thickness is much easier on the kme. If you want to use something like shapton glass stones on the WE its more complicated since the thickness compensator for it is hard to find, expensive, and it is also more expensive/harder to find a pair of stones cut for the WE handles. Accessories and additional stones for the KME are much cheaper, I have no clue how the quality of the diamond plates of KME compares to WE.
The last thing to consider is the position of how the knife sits and sharpening motion. On the KME you can't see how exactly the stone contacts the blade but you can watch the edge as you work on it, you can also use the same hand to do each side. On the WE you cant normally watch your edge unless you pause, but you can see how the stone contacts the edge. You also need to get used to using both hands to sharpen like you would with an edge pro. On the WE you can use whatever motion or technique you want but also have the ability to do alternating strokes if you prefer.
From experience I found The WE makes it easier to get even sharp tips, it is harder to comes off the knife in the same way when you have to flip it and when the tip points towards the left and then towards the right. On the KME It should be easier to use light even pressure as you glide the stone along the edge, based on my experience using an edge pro type sharpener. Since the stone is laying flat on the edge due to the gravity you can use light pressure to glide it across and gravity will allow it to contact the entire length of the bevel with even pressure unless you apply more. On the WE you have to be more mindful of keeping even pressure along the blade, especially during the last finishing light strokes.
