- Apr 16, 2018
You definitely got the hang of it Jason and nice work. What grit did you finish up with?I think I'm getting the hang of it!![]()
I just started using a KME. Do you think I can achieve a mirror by progressing from 1500 diamond, to 6 micron lapping, to 4 micron CBN roo strop to 1.5 micron CBN roo strop? Or do I need the 9 micron lapping film as well?Jason Mr.Wizard nailed it on that short statement^. I've been using the KME for a couple months now and I just picked up the full lapping to try mirror finishing and I have had great success. You will be amazed at how precise your edges will be and it's very easy to achieve perfect mirror edges. Quick tip #1: Always start out lapping with downward strokes and only run the film a quarter of the way past the tip of the blade. Later when you feel comfortable using them you Can use a back and forth motion with little to no pressure applied but again start of with downward strokes first then back and forth motions. tip #2 to avoid contaminating your films with the corser grits I rinse the films in warm water and dish soap before I use them and I wipe the blade clean between each gritt. Honestly it's very simple to achieve a good reflective edge with very little practice.![]()
