I got my Esteem packages last Saturday and finally had time to get started today! It was packed well enough, the VFD box took a few hits to one side particularly the outside cooling fin corners, looks like the post man was pretty rough with that box, maybe because it was the lightest box and he was angry? Just one of the cooling fins was bent a bit, no big deal.
Anyway, I wanted to give the variable speed a quick test with the motor to make sure it all worked. As it turns out all of the outlets in the garage are protected! It turned on for a second and I could start the motor at the lowest speed but as soon as I started to give it any power it tripped the protected circuit. I did read the manual before I powered it on and I already knew it didn't work with protected circuits, I just didn't know ALL of the garage circuits are protected, strangely they are all on the same circuit as the upstairs bathroom! I will finish testing it tomorrow with an extension cord to an inside outlet... I am certain it will work fine. For now it seems I will be wiring in a 20amp unprotected outlet or I will have to hire someone to do it. I have to look into code yada yada yada... Good thing I am in no major hurry, but I am excited to give it a try.
Well here are some pics;
Here are all of the parts before I built it, mostly unwrapped, so far unwrapping things and cleaning up packaging peanuts took the longest. It only took about 10-15 minutes to get the frame together and the motor mounted and wired. Brett did a great job wrapping the metal components:
Here is the partially built grinder. I will probably finish it tomorrow if I get time. I can't use it until I get that new outlet so I will be sad looking at it when it is done.
