I've had one for a couple years now... It's been a machine that I've had to tinker with in order for it to work in an acceptable manner. My biggest complaints about it are the belt wobble--solved by squaring up the drive wheels and installing a better tension spring or gas piston--and the fact that it's about as smooth as a forklift driving down a washboard road. The pulley system produced quite a bit of vibration and only gets worse as you ramp the speed up. The cheap quality bearings they use don't help at all either; I've had to replace almost every single one on the machine and I'd consider that unacceptable considering that I only use it a couple times a week at best.
Overall it's a decent machine and I've turned out a bunch of really nice knives on it, but there is MUCH better out there for comparable money. For a few bucks more, I'd seriously look at Esteem grinders. They run MUCH smoother and quieter--direct drive is the way to go in my opinion and I'm currently saving up my pennies to do a direct drive conversion on my KMG.
JBC69, do you have any resources to point to for getting a KMG less wobbly. I'm a complete newbie when it comes modifications, but i'd like to give it a whirl.
JBC69 said it all right there - direct drive. "IF" I were considering a purchase of a new KMG I'd push very hard to get them to drop the pulley/shaft setup and drop the price some. The price drop should just about cover the cost of a Chinese VFD drive, and the 3 ph 2 hp motor required would be about same cost as a 1 ph 2 hp motor. Simple to just bolt motor base plate direct to mounting plate for grinder.
Later
http://www.bladeforums.com/forums/showthread.php/1351035-Converting-a-KMG-to-direct-drive
Handful of things shown in this thread.
It's hard to explain it all, since it was actually a pretty big procedure.
Since there are no dowels or anything in the build, and the screw holes are oversized to allow the screws to fit, the whole machine wasn't square.
I started by making sure the receiver for the arm was actually square to the drive wheel.
It wasn't, so that took some creative adjusting and measuring.
This is an important step, because otherwise the drive and driven wheels end up with axis that are not parallel with each other. something like this \ |
They need to be parallel, more like this ||
Hope that's clear, because it's the key.
Once that was done, and I was sure the axles weren't cocked in relation to each other, I put the tracking wheel in a neutral position, and took a measurement off of it.
Again, no easy task, I had to get creative.
I then made sure the centerline of the drive wheel was on the same plane as the tracking, and did the same for the wheels on all the tooling arms.
All was better after that.
Maybe a drawing will help a little.
This is looking straight down on the grinder, it's just the wheels.
You can see on the right, what I started with.
The wheels were crooked in relation to each other, and the centerlines didn't all line up.
The left, is what you want.
By the way, I discovered all of this, when I built my own grinder.
I made a 3 wheel grinder that tracked like a dream, and when I moved the belt to the KMG, it wobbled all over the place.
Same belt, 2 machines, 2 different results.
I investigated, and fixed it.
It seems like when the wheels are crooked to each other, the drive wheel is trying to drive the belt off of the contact wheel/platen/slack belt.
It only gets so far before the tracking wheel overcomes it, and brings it back.
Diving off and coming back = Wobble
At least that's today's theory.
Josh, is the spring starting to get weak maybe?
