Erin Burke
KnifeMaker...ish
- May 19, 2003
Because making a knife isn't quite difficult enough, I decided to add a camera to the mix... really spice things up.
Feel free to comment on how I am doing things. I'm a new guy with only four knives under my belt. Any advice would certainly be appreciated.
This knife will hopefully end up being a decent-sized fighter with a nice hamon. I am using 3/16" 1095 from Kelly Cupples. Typically my first step is to produce a sketch. Since I am currently exclusively a stock-removal guy due to restrictions in my shop space, my designs are limited to the size of bar-stock I am working with. I have some 1-1/4" bar and some 1-1/2" bar in 3/16"... for this particular knife I chose the 1-1/2" bar. So I drew up the design shown below to fit the bar stock. To make my pattern a bit more rigid I will glue it to a manila folder (w/ glue-stick) before I cut it out.
I then trace the outline on the bar-stock and start cutting out on the bandsaw. Below is a photo of my hairy-knuckles and my DeWalt portaband in action. This is a great saw and I highly recommend it to anyone looking for a quality knifemaker's bandsaw that takes up minimal space. :thumbup: You will have to build a replacement table though.
The following photo shows the blade fresh off the saw.
I then head over to the grinder to clean up the profile using an 8" wheel, an 1-1/4" small wheel and an old 40-grit 977.
To be continued...
To be continued...
