- Jun 9, 2006
If you fight a bear with a knife it will most likely kill you.
It is best not to fight with a bear but to give in and "play dead" if it is on top of you.
If a big cat sees you and really wants to eat you there is a good chance it will,
unless you are armed with OC or a firearm.
Although this is rare, I've had a friend attacked by a mountain lion.
Luckily she survived but is now missing an eye.
It was an old sickly mountain lion, which her friend dispatched with a knife
from behind.
With a big cat make yourself look like less of a deer as possible. Take your shirt
or jacket and raise it to chin level so your neck is not exposed. Since, a cat
will go for your neck, if it has trouble discerning your neck it will be less likely to attack. Also, look the cat in the eyes and back away slowly.
If you turn and run it will chase you.
In areas of known bear or cat populations I take bear spray. So, far never had to use it.
But it's legal and has a seemingly effective track record.
I would agree if we are speaking about a Grizzly or Polar bear...the Black Bear on the other hand is going to eat you right then and there...fighting hard is highly reccomended..a cat will most likely be attacking from the rear, as a suprise..you might have a split second to react, stay on your feet if possible...and fight like hell. This is ofcourse just theory, but the cat is very agile, and will have you at a serious disavantage if you are on the ground...
if all you have is a knife, it isn't a bad alternative to a gun if used as a stabbing impliment, slashing doesn't get the job done very well. All combat usually means both parties are wounded..particularly when sharp stuff is involved (claws, teeth and blades)....hopefully nobody here ever has to deal with any of this nasty stuff. JMO
