Neither of the blades we are discussing were designed with batoning in mind, no Bowie/clip point really is unless you have one quite a bit longer than these. In the 5" blade of the AFSK about 2" of that are lost from the spine for the recurve. Not much left after that to baton with.
Knives are not pry bars. If you are bending the blade of a knife the solution is not to get a stronger knife the solution is to get a pry bar.
The USMC knife was designed as a fighter/utility knife. The AFSK as a knife that could be used for defensive purposes but more with utility in mind. Both are multi-purpose. Neither takes the place of an ax or machete nor was intended to. Yep you can chop through some small diameter branches or saplings but these are not primarily choppers.
Both can skin game. The AFSK has an edge here as it is a handier size for that purpose. The USMC knife is a better choice for a fighter given it's length and weight but the AFSK ain't bad at that. Both are good at wacking up some kindling. The AFSK is a tad better for attaching to the end of a branch for an improvised spear. The butt of the AFSK is meant to be used as an improvised hammer for light pounding, as with a stake or such.
A few decades back when I worked on a commercial crab boat I had a AFSK and a Ka-Bar to work with on boat. I preferred the AFSK for it's size.
Both knives are classics and useful to have around. There are stronger knives about and better camp knives or hunting knives but both the knives we are discussing can be good friends in the field. Spending some time with them you can learn the strengths and weaknesses of both.
tipoc
tipoc
