- Dec 3, 1999
>>>I have a med kit that contains a bottle of boric acid. What/how do I use it?<<<
Boric acid can be poisonous to humans in sufficient doses. However, my *guess* is that the boric acid in your kit is a dilute solution intended for use to treat pink eye or conjunctivitis. Conjunctivitis is an inflammation of the conjunctiva, the mucous membrane that lines the eyelids. Conjunctivitis can be caused by a bacterial infection, injury, allergies, or irritants such as smoke or chemicals. The eyes may appear swollen and bloodshot and are often itchy and irritated. The conjunctiva may become filled with pus, so that the eyelids stick together after being closed for a while, as in sleeping. Putting a dilute solution of boric acid in the eye is a standard treatment for conjunctivitis; but I would urge you not to use this apparently poorly labeled bottle of stuff unless you are damn sure what it is.
This raises an issue that may be worth discussing. I dislike prepacked medical kits. They often contain mystery substances, like your boric acid. They often contain things you dont need, packed as filler to make the kit look complete; and they often lack things you would want to have, if you thought about it. It is, in my view, much better to compile and pack your own medical kit, for several good reasons. It is often cheaper to buy individual items instead of a prepacked kit. You are able to select from among competing products. You know exactly what you have. You do not have things you do not know how to use. You will know where everything is, because you have packed it yourself, and everything will be packed so that the most important gear is most accessible. You will be able to make the appropriate size-weight-utility trade-offs for your trip and your team. You can make your kit modular in a way that makes sense to you. Most important, compiling and packing your own kit makes you *think*. It makes you think about where you are going to be using the kit, about the potential hazards in that area, about how you will deal with those hazards, and about the scope and limits of your training and experience. That can only be good.
[This message has been edited by Walks Slowly (edited 30 December 1999).]
