I have a question on edge testing, I forged a blade and quenched then tempered it, then thought when a knife is used in butchering a deer! if the person using it is silly and tried to cleave bone with it, this could damage the edge! So I chopped away at a piece of dried cow bone. The edge showed some small dents and wear, but I cleaned them up easy enough with a sharpening stick with a little time or effort. the force I used is hard to measure, when chopping at the bone! but maybe the force used to hit a table, to get attention! would be a good discripton of the force used. your hand would likely hurt after!! I think I have the heat treating right, I was able to pierce a piece of 16 gage auto body sheet metal with the tip and was plesently surprised the was no real damage! just looking for opinions ! thanks for reading..... this the knife is 1/4" at the spine near the handle and tapers to 1/8" 3/4 of an inch from tip, the blade is 1 and 1/4" wide 5 1/2" long. the grind is weird!!! a wide flat grind with no bevel at cutting edge so from 1/4" to 0 over 1" the beveled grind on spine takes the last 1/4" ""is it wrong to have no second bevel at cutting edge? the bevel is a very sharp angle at the edge, to the point you have to be watchfull not to scratch the flat grind when sharpening?
