Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
mike I think it's the time period that helps not the small amount of cold.fitzo said:J, I think that what you state is consistent with what Kevin said....under usual circumstances austenite would be expected to convert relatively quickly once a lower temp is reached. The higher the alloy the lower the martensite finish temp (Mf). There's no doubt that cooling some steels beyond where one would normally stop in "quench" helps, even if it isn't full cryo.
My point is only that I observed circumstances under which hardness increased over a period of several days in a high alloy stainless as measured with a hardness tester. I observed this multiple times. Not being well read in metallurgy, I can't propose an explanation. Spending my working life in science, though, I do trust my powers of observation. Something was going on in those botched up hardenings.
I hope someone may be able to explain...it has long been an interesting question to me. I have mentioned it before.
bladsmth said:I stayed out of this to start with,But since it has come around to being a reasonable debate,I'll add my thoughts.
I agreefitzo said:Here I thought it was a discussion, trading different understandings,.....
fitzo said:It was unreasonable at some point? Or a debate?![]()
Here I thought it was a discussion, trading different understandings, ...
Dan Gray said:... Kevin
if so does this mean we should Cry'o more than once?
or did I misinterpret you? that could have happened un-doubtfully![]()
