Yes, I was using CLP and other gun lubricants like fireclean but so runny, seemed good for the bearings but was looking to keep the blade protected, especially damascus, I have heard Ren wax a lot so I am going to have to give that a try.
If you do 'regular' maintenance, just about any oil will do.
Mineral oil, 3-In-One, WD-40, even synthetic motor oil like Mobil One and car waxes work just fine.
Frog Lube is a highly recommended 'premium' lube.
Food grade mineral oil,ikea sells it by the pint 5 dollars been using as lube and protectant
Wow. I just checked out your website. What does a wax like your PineUltimate do exactly? Will it completely protect a tool steel from corrosion? Does it hold up to abrasion during cutting of soft materials? I waxed a couple blades with pure Carnauba wax but it was a hassle - had to heat the blade first and the wax is extremely hard, so buffing was difficult.I'm biased, but I use my own.
• For oil I use my Desert Whale liquid wax, which is about as light as sewing machine oil but is food safe, non-petroleum, and non-drying.
For wax it depends on if I'm using it on steel or on wood.
•On wood I use my Super Safflower wax which is food-safe and polymerizing like linseed oil is, but with microcrystalline paraffin and polyethylene wax, which is even harder than carnauba wax (and happens to be the same wax used to line milk cartons.) The safflower oil darkens wood less than linseed oil, and just as polymerizing, but doesn't yellow with age.
•On steel I use my PineUltimate formulation which is a solvent wax like Renaissance Wax is, using the same micro- and PE- waxes but with some cetyl palmitate for smooth application, and some high-grade VM&P naphtha blended with α-pinene and α-terpineol, which are both terpenoid solvent compounds found in turpentine. Those compounds are slower evaporating and raise the flash point of the naphtha for safety, while also helping to hold the matrix of the wax open as the naphtha evaporates, before evaporating themselves and leaving only the waxes behind. It's a little slower to dry than Renaissance Wax is but ends up fantastically hard and buffs clear, though it will feel tacky when the naphtha is evaporated but the terpenes have yet to evaporate. It buffs up nice and bright once the terpenes clear, and their pleasant pine-like scent is the indicator of if any is left behind or not.
All wax will wear in use but the wear points aren't where protection is most needed--the low points where the wear doesn't occur are! Use will keep the wear points clean. However, the polyethylene wax in PineUltimate is exceptionally hard and durable and wears slower than other common wax finishes. Because it's a solvent-based wax, it's kept soft by the solvents and made smooth-spreading by the cetyl palmitate, which is a hard waxy solid and room temperature but is used chiefly in cosmetic products for improving the "slip" of creams and lotions without making them greasy. The main reason polyethylene wax isn't used in more polishes is mostly that it's a bit of a pain to work with--it has a VERY high melting temperature and only becomes soluble to aliphatic and aromatic solvents when those solvents are heated! once dissolved it also has the tendency to recrystallize and separate out, which is another thing that the cetyl palmitate helps with, along with the α-terpineol.Wow. I just checked out your website. What does a wax like your PineUltimate do exactly? Will it completely protect a tool steel from corrosion? Does it hold up to abrasion during cutting of soft materials? I waxed a couple blades with pure Carnauba wax but it was a hassle - had to heat the blade first and the wax is extremely hard, so buffing was difficult.
