Esav Benyamin
MidniteSuperMod
- Apr 6, 2000
One other point about benchstones and the Sharpmaker. The Sharpmaker can be used as a benchstone.
If you start with a coarse diamond benchstone, you may mess up the edge by overdoing it. If you turn the Sharpmaker base upside down, you will see two grooves in the bottom that fit two Sharpmaker rods. Lay them in there and practice freehand with the ceramic, which will give you some results and a learning experience without harming the edge.
Use the marker trick to see how well you're doing: cover the secondary bevel with marker ink and then sharpen away. This will show you if you're sharpening the whole bevel evenly, or hitting just the edge or just the shoulder.
