Knife recomendation
Con any one recomend a good knife? I need one that meets these qualifications. I am going to the Cal. Maritime Academy this fall and I am required to have a knife.
1. Must be a folding knife
2. blade cannot exeed 4 inches
3. Needs either to be Stainless Steel or have a rust prohibitor
4. Useful in a Maritime Enviorment.
PRK Inmate
I usually dont jump into these questions.. but I really liked your handle.....my recommedation.......DO YOUR HOMEWORK> go to www.bladeart.com/ and www.knifeart.com/ and www.tripleaught.com/ and check out their offerings......corrosion resistance means a lot of different things to a lot of different people......there are a LOT of old threads in the archives on this...check them out.......also...you didnt put a price limit. that is a prime factor in what you are going to get......If you lose knives often dont spend too much...Columbia River might just fill your bill......If I were to tell you what to get.....Id say START with a sebenza and work up.....
http://www.mayoknives.com
John 1:14
Love is Stronger than Death!
You cheapest choice and one that would be the most corrosion resistant would be the Boker one designed for saltwater. see their website.
For serious use, you can't go wrong with a Chris Reeve Sebenza. If you're after something even more rust resistant, a Tom Mayo TNT would definately fit the bill.
"I'm out there Jerry, and I'm lovin' every minute of it!"--Kramer
The most important question ~ what's your knife budget ?
Livin' Life ~ Full Throttle
The most I can spend it $100 and I don't really want to pay that if I do't have to. I looked at some of those prices on the first link, GOD DAMN!! What are they made out of? I would only spend that kind of money on a new glock or two!
PRK Inmate
Spyderco Rescue with orange handle.
Good style for marine use, decent rust resistant steel, easy to use, easy to find, half your budget so if you loose it overboard you can use the spare you bought.
James Segura
San Francisco, CA
Hello, Myerchin makes a good selection of marine knives. Most are under $70.00 and I've seen them for sale around $45 on the internet. Myerchin is at www.myerchin.com
The marlin spike is always nice to have working around rope. Good luck at the academy. Regards, Greg
A377P75%20large
[This message has been edited by Ripper (edited 06-18-2001).]
I have your knife. Actually two of them. Lead originated with Tom Mayo. For $100 you can get two Columbia River M-1613LEs. They are very light and have 3.5" blades that are Teflon coated for corrosion protection. They have serrated portions on the blades perfect for cutting rope or cord. A brace of them for $100, so you can rotate them, or kill one completely and move on to the next one.
Sorry to inject gloom into the frivolities, but in my experience, getting into fairly large group situations means at least one thing -- besides not dropping your soap -- theft. Expect to lose things to sticky-fingered peers. So, indeed, I'd go as cheap as you can, w/out getting out of the realm of usefulness. Too bad they have to be folders. Otherwise, I'd suggest Frosts Clippers in SS. $8 a pop at SMKW.
Unless you get a blade coating that you know works well, I'd invest in a Sentry Solutions Marine TufCloth. Treat your knife several times before heading to the academy, then treat it weekly.
ALmost forgot to welcome you to the forums, celticjedi. Hope you'll hang around and enjoy yourself. Much to learn here, plus some fun to be had.
Also, welcome to reality, in terms of knife prices. Think of it this way -- a knife is a tool. A good tool should last for several years, perhaps a lifetime. Surely worth more than the cost of a couple-3 CDs or whatever. Definitely more than the cost of taking a girl to a movie and for burgers. So, just have a summer of ascetism, and you'll have plenty of bread for a good knife or two.
Try to buy on the Internet if you want the best prices. It's not necessarily fair to the brick and mortar stores, but some folks go there to check out knives in the flesh, so to speak, then order over the web. Many threads in this forum, more in G,B,&U re better dealers/sellers.
Asi es la vida
Bugs
Try the Boker Angler. It has a blade made of X-15. It's supposed to be perfect for what you are looking for.
Well since Im sure you'll be doing lots of brass polishing while at that academy, instead of using a tuf cloth (or better yet, in addtion too) give the blade a light polish at least once a week. This will remove any light surface oxidation as well as smoothing over the surface slightly, which will add to corrosion resistance. I too would recommend one of the spyderco's, namely the endura or the rescue.
I own a number of knives and I have to say the CPM 440V steel used by Spyderco has held of rust amazingly well, better than ATS-34 or 154CM when they had Tuf Cloth on them and the 440V blades did not.
Based upon that, I would recommend the 440V Native for a low cost knife, the Starmate for a good blade with a very strong tip or the Military for amazing cutting performance.
All by Spyderco.
Failing that a Sebenza...
Wayne.
"To strive to seek to find and not to yield"
Tennyson
Ranger motto
A few useful details on UK laws and some nice reviews!
http://members.aol.com/knivesuk/
Certified steel snob!
If you're primarily going to be cutting line, etc., I'd second the orange Spyderco Rescue. I've used it skindiving and rafting. If you rinse and dry it, no real rust problems. A friend of mine does boat maintenance in the marina and he uses one to cut line tangles off props and other boat components. It has held up well for him too.
DPD.
Celtic,
Welcome to the forums! I need to respectfully bring something to your attention.The general forum here is a family forum. Lots of younger folks, and even some older folks would appreciate some modification of your language. We try to keep it fairly clean here. In the Whine + Cheese forum, anything goes. As a moderator here, I have the ability to edit your comments, but choose not to. I hope you will. Thanks for your consideration.
David
AKTI# A000150
NC Custom Knifemakers Guild member
NC Knife Knuts member
[This message has been edited by davidb415 (edited 06-19-2001).]
I've got the perfect knife for you. It's the Spyderco Snap-It or the Spyderco Remote-Release. Both sell for about $30 to $50 (provided you go through an internet dealer like Discount Knives at www.discountknives.com , or some other, etc. and possess AUS-8 steel which is very good at resisting rust. Also, both are specifically designed for this purpose (and also for mountain climbing) where you need the knife shackled to your backpack/suit/etc. Their attaching mechanism and their serrated blade shape are perfect for this kind of activity.
Good luck!
-Flood
