Cyber_Demigod,
Canned air: agree may not get all moisture out, but it helps. Other options: oven on low heat, silica gel (desiccant), to name two. If you have compressor at home, bitterant no longer an issue.
Agree WD40 CAN GUM up the works IF YOU are constantly applying it. Just a little post knife cleaning shouldn't be an issue, I would think.
And most knife hinges - as far as I know - require some lube. So what light film lube alternative - oil or grease - is there? Lithium or axle grease or other would be worse IMHO.
Alcohol allergies: to isopropyl only or all types? Do they still have a problem if using nitrile or latex gloves? If isopropyl only, try Everclear (or Chinese baijiu as some have higher octane than Japanese sake!)
Solvents: Carburetor cleaner is another option. Don't remember ingredients. However, wasn't damaging the scale an issue? If so, this and other industrial solvents make not work; some likely to melt the plastic, others mar the finish.
Sanitizer: I have never seen Benz. Chloride in high concentrated form; only diluted (3% or so). One fluid form, as opposed to cream or gel, is J&J's No Hurt disinfectant wash. Its in a baby blue bottle and can be found in the first aid section of stores.
Anyway, my thoughts on the matter. YMMV.
Best
ETA: Benz. Chloride - Brand above is wrong though company (J&J) is correct. Brand is Band-Aid Hurt-Free Antiseptic. Benz. Chloride concentration is 0.13%. In fact, my statement of it being up to 3% is likely too high. Would need research that.
Sent from my Sero 7 Pro using Tapatalk
