Knife Shop for Sale - TW-90, Paragon 2-zone kiln, 50w Fiber Laser, Mini Mill, Tumbler, more
Feedback: +5 / =0 / -0
All items local pickup only in Berks Co, PA, you haul from basement workshop, cash, earliest pickup date 4/22​
Pics here: https://reading.craigslist.org/tls/d/boyertown-tw-90-belt-grinder-paragon/7609769475.html
TW-90​
Sold
Paragon Double Barrel 14T Pro 2-Zone Kiln​
$3000. In very good shape, bought new in 2021. Includes wheeled cart, argon tank with flowmeter/regulator.
50w Fiber Laser with Laptop & Cart​
Sold.
LittleMachineShop HiTorque Mini Mill, Deluxe​
Sold.
TX PHR-1 Portable Hardness Tester​
$500. Excellent condition, calibrated, includes case, calibration blocks, stand. This item can be shipped UPS.
20 gallon Rotary Tumbler with Load/Unload System​
Parts only
Import Bandsaw​
Sold.
Forced-Air Breathing System​
$500. It's a DIY assembly composed of a 3M M-206 Versaflo Faceshield, 3M hose connection hardware, ~20 feet of PE tubing (not vinyl!), water cooling tub, high-pressure air blower with intake filter.
Wet Grinding Booth / Spray System​
$500. DIY. Booth footprint is is 4'x 6', 8' high. Booth includes white PVC semi-rigid ceiling panel, 3 walls made from one seamless piece of white pond liner on a galvanized steel frame, floor made from one piece of black rubber pond liner with a pressure-treated wood frame. You mount in your workshop, the walls hang like a shower curtain. The spray system connects to your water line, the incoming water is mixed in-line with borax to make a corrosion-inhibiting solution. The system includes two stainless steel 5-gallon in-line borax mixer/reservoirs, tubing, in-line filters, remote-controlled solenoid valve, spray assembly with 3 flexible loc-line spray arms.
I'm interested in the laser.
Can you tell me a bit more about it - Brand, model, etc.? How many hours on the tube? Any accessories or consumables besides the computer and cart?
Can you show an example of a mark done with it?
Example of deep engraving (my photo, my work):
Example of color marking (my photo, my work):
It's a SFX brand with a 50w JPT limited MOPA source. I bought it new on Amazon here https://a.co/d/6RwhTc0. Fiber lasers have no consumables, the source is solid state (no tube). I believe fiber laser sources are rated for over 100,000 hours of use, you'd have to look at the manual here to confirm https://www.manualslib.com/manual/2063607/Jpt-Lp-Series.html. It comes with the two lenses mentioned in the post - 110mm square and 170mm sq. Also includes safety glasses, I forgot to mention that. I'd estimate the total hours on the machine as less than 100.
Fiber laser lifespan: https://www.laserfocusworld.com/ind.../14220525/four-reasons-to-choose-fiber-lasers
