Knife sounds
How important is the sound of a knife to you? I particularly mean folders and flippers. It is not called walk and talk for nothing is it?
I like a reasuring heavy clunk( i don't know if that's the best way to describe it), like a volvo car door closing as compared to a tinny sounding fiat panda door, even on a slipjoint I find myself looking for that snap noise when the blade drops into place,.When I am playing with the knife, if the sound it makes is not appealing I put it down and fidget with something else.
There is definitely something to it. Sharp, decisive sounds can indicate good build quality and robustness. I esp. like the sound back-locks give.
A cold steel triad lock opening with a snaggletooth LLC gives a very loud clack. You know when you just opened it. And so does everybody else . It may just act as a deterrent sometimes just my worthless two cents
I’m a big fan of the acoustics. It doesn’t make or break a knife for me but is more like an added benefit. I tend to like thicker blade stocks. I like a knife that feels like it can handle anything I throw at it. Usually with thicker stocks comes the better acoustics that I enjoy.
My favorites are my LG’s cause they fly open with just the slightest flick of the thumb and make an excellent thwack sound.
Second would be my CRK’s, while not as loud they make a sound I just enjoy opening as well as closing
Third would be my Emersons when using the wave feature.
It's one of those things that while not expected, is usually appreciated, within reason.
I generally like thin blades so most of mine don't have the weighted smack on the stop pin.
However, some the lock engaging has a very nice sound, an example would be my Cheburkov Strizh. This is especially surprising in that it's a liner lock, and fairly thin at that.
Best sounding knife is probably my Demko AD 20.5 followed by my Alan Davis is you push button it. The Cheburkov and Biryukov #7 are tied for 3rd.
My Axial Shift is probably the worst, very audible "ting."
Oh I forgot, my Heretic Medusa (auto) has a very satisfying thwack.
Of all my knives, the Rassenti Druid Integral sounds the best when it locks open, as well as when it closes.
I love the thwack of a good backlock. I also love the sound of my Norseman, which I can’t really describe. No other knife sounds like that, but it’s sexy!
😂 That's my first thought
The only area I've heard people talk a lot about knife sounds is with the balisong crowd. They can be picky about how the knives sound as they're being flipped around, particularly whether or not they "ring" as a result of the parts being machined in a way that causes them to resonate like tuning forks.
Personally, I notice when a knife sounds different but it wouldn't be the deciding factor whether I keep it or not. The sound can be affected by a lot of things like the locking mechanism, detent, construction of the knife, etc. Some of the more notable ones in my collection are:
Pohl Force Mike One: This one has a particularly solid and damp thwack. My theory is that it's because the teflon washers don't scrape, the titanium on steel lock seizes up solid, and nothing on the knife rattles. The fasteners are wedged so tightly into the handle that it's a royal pain in the ass to take apart, but it does dampen the sound enough to make the knife seem more solid.
CRK Umnumzaan: Super quiet because of the o-rings on the blade stops and the oversized ceramic ball interface.
Spyderco Phoenix: Next quietest after the Umnumzaan; the ball lock engages quietly and instead of a stop pin you have two solid titanium surfaces come together.
Maxace Sandstorm: Despite being an oversized and overbuilt knife, the sound it makes isn't the most reassuring. It has an extra hole in the blade that you can stick a pin into when open to serve as a secondary lock. When opening and closing the blade, the detent clatters across this hole in addition to the detent hold and lock face. Instead of a solid, singular thwack, you get something that sounds kind of like a quick, hollow rattle. It doesn't detract from the knife functionally, though.
Cold Steel Espada Large (aluminum): This one I think has the most impressive thwack in my entire collection. The knife is built very solid with no rattle, and the large black has a lot of inertia hitting the stop pin. But the biggest difference compared with my other Tri-Ad locks is the stiffness of the spring. It's stiffer even than the Rajah II, which is a bigger knife. That means that when the lockbar falls into the blade, it does it with more of a bang than any of the others I've tried.
That's funny, I kind of like the sound the Shift makes, reminds me of the hammer dropping on a revolver. I prefer it over the sound my Hogue Incursions make, since they have the distinct tone of metal surfaces scraping over each other (possibly due to tighter tolerances since they have less play than the Axial).
Is it possible that the dull sounds are an indicator of the steel type and heat treatment and not just the mechanism?
A dull thud - soft low HRC steel.
A light ting - high HRC steel, like two ball bearings being clanged together ?
Exploring that a bit further the close might be more indicative,
