knife-spear
If this has been discussed I apologize. I don't have the search feature :o
What is the best way to lash your knife to a stick to create a spear?
pics would be great!
What circumstances would demand this? Why not just carve a point?
Thanks all!
You made the most relevant case against it in your post. Why not just carve a point?
Why not?
Why would you risk your most valuable tool in a survival situation in order to make a spear?
Dunno any good reason to do this. I just simply would not risk the knife. Or any of my prescious chordage either for that matter.
The last time I made a spear (just for fun), i found a branch like a slingshot and split the ends into 3 section per each limb. I wedged rocks in between the splitted ends and tied them off tight. Sharpened the ends up and split the bottom of the "Y" I then attached my fashioned spear head to my walking stick. It worked out pretty good and was something to do while I was freezing my ass off waiting for morning to come.
I think I have a picture (go and checks webspace). YEP! here it is.
That would make a good fishing spear 8U. Cool pic.
That was the intention. When we were hiking in there were lots and lots of small lake run-off pools loaded with trout. It was the most fish I had ever seen in the wild (even though they are stocked trout). Picture the fish pond at a Cabelas or a Bass pro shop and add 1000 more fish. I made the spear that night in hopes of getting a few, but come morning time there were guys fishing these tiny ass ponds:thumbdn:. It was one of those occasions where the limit was 8 fish and guys were carrying out 80.
Carve a point and then harden it with fire a bit.
that would probably be your best bet....:thumbup:
the cold steel bushmans are great for that as well... they're fairly cheap and hold a great edge... if i were to use a knife, it would definately be a smaller one, and not my main blade....
Just stick it in the coals for minute. But don't let it stay in there long enough to burn.
t doesn't harden the wood so much as dries it out. Dry wood has less tendancy to bend at the point :)
I keep a few wood screws inside the Bushman handle (among other items). My Bushman has a couple holes in the side so I can screw it to a spear shaft with my SAK. As others have noted, I'd be a bit reluctant to do that if it was my only blade.
Well, gee, if a carved point (or points) works fine, I don't see the need to ever lash the knife. I have never spear fished, so I just assumed that maybe lashing the knife would outperform the carved stick, or maybe that lashing the knife would ward off predators more effectively or something...
I've never spear fished either but I assume you want to have the majority of your weight and control at the holding end of the stick, not the front. If you stick a big knife up there, then it's going to affect your speed and accuracy, which is what spear fishing is all about. Plus, if you carve a point, you can make it as thin as you want, and add backwards serrations.
Why not just buy a CS boar spear blade and use the shaft for a walking stick? For spear fishing or small game, a pointed stick works, but for defense against large predators, I can see the need for a steel spear blade. Keep the varmints at distance and hurt them. The spear is an ancient and effective weapon.
I agree. The knife is a cuttin tool. Not a spear, or shovel or anything else. IMO
