- Jan 6, 2014
Hello everyone! I have a batch of 7 knives made out of a mystery high carbon steel. The steel came from a farm implement disk, and is high carbon of some form. It throws long, feathery sparks when ground. I quenched the thinner ones in used motor oil, and ended up using hot water to quench the thicker ones after failing to skate a file out of the oil. All 7 knives, plus one from an older Nicholson file, skated a file after hardening. I put them all in my regular cooking oven for two two hour cycles at 400 degrees. As they were still too hard, I did one more two hour cycle, for a total of three so far. As they were still too hard, I then put them in for a two hour sit at 500 degrees. Now the file doesn't quite skate off of it, but certainly doesn't dig in like it should. I cleaned the scale all off after the first cycle, so I don't think it's that. Also, the two hour cycle was from after oven was preheated, not from when knives were at temp. So what's your best guess of what's going on, and how do I fix it? I know, mystery steel, motor oil, water... But I'm worried about getting these done, and I'll worry about a better quenchent and steel for the next group. (1084 and canola?) thanks in advance, I hope you can help!
