Knife terminology?
Monofletch
Is there a thread somewhere with a grouping of the terminology some of us use? Things like…..
Production version-
one off-
detent rock-
Tip up/down-
Swedge-
Blade play-
High carbon-
Stainless-
OEM-
Scout carry-
Warnie-
Fixed-
Secondary
Primary
Convex
Flat
Saber
Chisel
Zero
Hallow
Scandi
HRC
Differential temper
Impact resistant vs wear resistance
Oil hardening
Air hardening
Whatever else you can think we need to know!
Give me some definitions of these. We will get a nice list together - then try to group like terms togetger
"Behind the edge" was one that was making the rounds a lot a while ago. It refers to how thick the main body of the knife is, which affects how easily it can get through something once the material you are cutting passes the tip of the edge. A thin knife slices better whereas a thick knife encounters more resistance because no matter how small the edge angle is, it if it keeps getting wider then you lose cutting performance the deeper you go.
Thesaurus. A knife one.
Thesaurus - a dinosaur with an obnoxiously large vocabulary.
Knife Thesaurus - An overly verbose dinosaur that you don't want to mess with.
F&F, which could mean two different things depending on whether you are selling or describing a knife
