Cobalt
Platinum Member
- Dec 23, 1998
If you want to perform testing under conditions that will be the same every time, then you cannot, test paper or wood products for the reasons you have mentioned above.
What you can do, however, is test plastic products. High density Poly Ethylene(HDPE or PE), Polystyrene(PS), polypropylene(PP), PET, PVC, etc. These materials all offer very consistent properties from one batch to the next and offer a range of hardness for impact as well as slicing. PVC, for example is very hard. Pet is not as hard but much harder(tougher) that the others. PE and PS are soft and can be used in slicing comparisons. PP is another inbetween depending on the form you get it.
The only problem here is cost. If you can overcome cost, plastics offer an incredible option for testing. Try chopping up a plastic drum. Not Easy.
