There are several places where it could have gone wrong.
Edge Quench - Unless done exactly right, the heat in the un-quenched part will un-do the hardening of the edge. Plenty of folks love an edge quench, but I am not one of them. If you want a hard edge and softer spine, do a full quench, and then draw the spine softer after tempering.
Heating Method and Temps - The blade must be evenly heated to about 100 degrees above non-magnetic ( sorry fast14riot, non-magnetic won't be enough). Heat until the magnet won't stick, and then a little bit redder. For 1084 the temp is 1500°F. The more controlled the heat source the better. A torch will work, but a forge or HT oven is far better. Doing HT by eye with a torch is a skill that takes a long time to master ( and even then has failures).
Oil - The oil should be a commercial quenchant or fairly new canola. Other oils aren't usually suitable. Heat canola to about 100F.
Temper - The blade should be tempered twice at around 400F. Make sure the oven does not overheat, as some toaster ovens do.
