- Dec 19, 2002
Spyderco Manix2 XL C95CFP2, CPM-S90V, Peel Ply Carbon Fiber Handle,
Plain Edge (KNIFEWORKS EXCLUSIVE), (PRE-ORDER)
Suggested Retail: $274.95 Our Price: $219.95 You Save: $55.00 Free shipping in the USA.
A little over 1/2 of this run has been sold
http://www.knifeworks.com/spydercom...nfiberhandleplainedgeknifeworksexclusive.aspx
Limited to 2 Per Customer
Limited to 800 Pieces
Free Shipping in the USA
The large Manix2 is an oversized version of the Manix2 with a blade that is just under four-inches. The blade is locked open using Spydercos patented Ball Bearing Lock. The lock is comprised of a free-floating steel ball-bearing encased in a high-tech polymer cage. When opened, the ball bearing moves forward onto the blades ramp where it is wedged, locking the blade safely open.
The spherical shape of the ball rotates freely allowing the lock to self-adjust across a large surface, ensuring smooth and confident lock-up every time it is opened. The blade is CPM-S90V, ground full-flat and features jimping above the oversized 14mm Spyderco Round Hole. The jimping texture continues from the blades spine to the full-length skeletonized steel liners.
length overall 8.94" (227 mm)
length closed 5.1" (130 mm)
hole diameter .56" (14 mm)
blade length 3.86" (98 mm)
cutting edge 3.44" (87 mm)
blade thickness .125" (3 mm)
blade steel CPM-S90V
weight 5.9 oz (168 g)
handle material Peel Ply Carbon Fiber
