- Apr 18, 2022
Knives like the 55, the 501, the 503
in Full Auto.
I'd prefer a Buck otf than those....
sure blade shape wise as an option...id expect no less......A Buck 110 OTF!
A Buck 110 OTF!
I'm not sure, but, believe that this is a desirable feature of an OTF. Here's a link to an explanation of OTF, single and double action.if you try to stab something and fire it holding it against something, the blade will retract. and may not lock in place.
it's not supposed to do that. its set up as a safety feature. it's for effective opening and closing..not for using to launch into something. a single action otf doesn't have this safety feature, but the spring still only has the push it has....and they also won't do that well, and aren't designed to do that either.I have an OTF knife and it is not of the expectations and all it is cracked -up. to be. You can, t expect the blade to come out and go through cardboard or even skin. It has enough power to lock in place but if you try to stab something and fire it holding it against something, the blade will retract. and may not lock in place.
The keyboard artist at Quora is a self appointed guru with self created information in the place of science and facts.I'm not sure, but, believe that this is a desirable feature of an OTF. Here's a link to an explanation of OTF, single and double action.
Can you stab with an OTF switchblade knife?
Answer (1 of 5): Out the front OTF knives come in two flavors, single-action and double-action. Single-action use a single spring to push the blade forward until it locks. If you happen to deploy the blade against an obstruction that prevents it from fully extending, as soon as you obstruction is...www.quora.com
That's a big blade.A Grandaddy Barlow![]()
