I have one and like it too but I had him make mine a tru scandi and the edge chipped off something awful like 3 times.
The Muskrat Man did great on pine and softwoods but when I tried it on some oak that was dried, nothing extreme just whittling thru maybe a 3/4" branch about half the edge chipped off.
I resharpened the whole thing, still scandi took it back out and same thing
Finally I gave up and put a secondary convex on mine and it worked OK.
I like mine now but I'm lukewarm on the steel he is using for a true scandi edge(unless mine was just poorly tempered)
Hmmm... I've used mine for several months now, but don't seem to recall using it on really hard woods or knots. It has always held the edge with no rolling or chipping on everything I've used mine for, but it's good to know if there are issues with the tempering... I'll give mine a test on some dried fire cordage I've got lying about and see how it holds up.
What do you mean by cutting power?
Scott
No other knife that I've ever used has the cutting power and efficiency of my Brian Andrews bushcrafter. (Nor anything as comfortable to use). But the scandi grind, 1/8" stock, and constant eliptical edge make it cut like a demon. :thumbup:
Scott
By cutting power, I am defining it specficly on wood. I guess the simplistic term would be "cutting the most off a chuck of wood with the least effort".
God Bless
+++ on the Brian Andrews bushcrafter. I recently got mine and have been beating the snot out of it. Great hard use bushcrafter. I got the 5/32 O-1 and had him put mesquite scales on it from wood that I provided. Great service.--KV
Was yours made to be a true scandi, or does it have a convexed edge?
A true scandi, will have a zero edge, so if the steel isn't strong enough or the temper is wrong; you get a chipped or rolled edge...
Mine's a true Scandi with flat grinds (why have a puukko with any other grind?).
Been getting home late so haven't had a chance to test for brittleness of the steel, but I will this weekend.
The only 2 times I've been disappointed with bad tempering was on a new Helle Troll and a Barkie. Both had edge chipping from simple wood work.
