The 2 in the first picture I wore down myself. It took about 25 years. Using them and keeping them sharp. (I sharpen differently now to minimize the belly loss they show).This is absolutely awesome! @eveled , those Bucks are the most worn down I have ever seen, nice! Are they that size because they snapped off and were re-ground by Buck, or were they worn down to that extent?
Not to derail the thread, I love well used knife pictures, but I’m curious about this. I’m not a freehand sharpener but I am slowly trying to teach myself with some stones and old knives as well as stropping. For my knives still in use, I use a Sharpmaker for touch ups/general maintenance, and I use a Wicked Edge for re-profiling. This combination works great for me, but I know it eats away at the blade more than freehand sharpening would, plus I’m a traditionalist at heart and I just want to learn.(I sharpen differently now to minimize the belly loss they show).
Absolutely, makes total sense! It’s basically the same thing I figured out using the Wicked Edge, but for a different reason. I hate how the cutting bevel would look wider (or higher up, I’m not wordsmith either) on the tip and belly and smaller/more narrow on the straight blade. So I started sharpening the straight blade first, then work on the belly to tip portion, lastly a couple strokes of the full blade altogether. I found it makes for a much more even cutting bevel aesthetically and functionally. It also saves a lot of steel, less grinding away, and keeps the blade shape closer to the original. Here’s an example of what I mean, the old way on the Becker and the new way on the ESEE.@JWright214 it began bothering me (with those 2 knives I wore out). That the blade is almost the original size just infront of the Ricasso then tapers off, with the most blade loss at the belly.
I realized by pulling the blade off the stone in a slicing motion, rolling around the belly to the tip(as I was taught), has problems. The edge near the Ricasso is only in contact with the stone very briefly so it gets minimal wear. The belly is in contact the longest and has a smaller contact patch so it gets worn the most.
Now I sharpen the entire straight section evenly keeping the whole edge in contact with the stone for the whole stroke if possible. Like I was sharpening a wharncliff or sheepsfoot.
Then I sharpen tip to belly separately (if they even need it), like you would a chisel. Think about how you'd sharpen a tanto. Except roll around to get the belly.
This picture shows it pretty wellView attachment 1840031
And I try to avoid this: with the tiniest of sharpening choils, ideally no deeper the the edge bevelView attachment 1840029
And I hate recurves View attachment 1840030
To fix a recurve I focus on the Ricasso side, and minimize loss at the belly.
I’m no wordsmith so I hope that makes sense.
Not always easy to tell the difference. Only the man doing the sharpening knows the truth.
