knives with glass breaker
-ResQMe
-spring loaded centre punch
-Holmatro glass breaker- pull back & let go spring action so yer hand doesn't go through the broken glass-the size of a pen AAA+++
-or the one I use for work-
good ol' smith & wesson 1st responder -folding lock knife & window breaker in one.
these work on tempered glass not laminated glass used in windscreens .
cheers
Look for the red pull handle on the window trim...they have a gasket that pulls out and then the window just lifts out or hinges out once the gasket is just pulled away.
I've had to use those on a train. It doesn't require much in the way of strength to get them off, maybe about 20 lbs to peel it away. But, that strip is a lot longer then it looks, so expect to be going hand over hand when you remove it.
Also +3 on the spring loaded punch.
well guys i know there is a gasket to pull it im not stupid xD but here our dear locomotion system changed 4 years ago and is called "Transantiago", uses electronic cards to charge your the ticket and in some routes a lot of people have to wait in the bus stop, sometimes you need to fight pushing people to take the bus xD , when the bus is full maybe you will not be near of those gaskets, so break a glass to save your life is a good thing, lots of this machine suffers an electronic or mechanical issue check this vid... im from Chile that's why my english is not so good
http://www.youtube.com/watch?v=Wnqrti2q8lo
Well i think ESSE HEST is prefect for me, low rider clip, a bottle opener and glass braker... i want one!
One problem with using a glass breaker on a knife is a lot of stuff can go wrong, some of them can even send you to the hospital, not that that option is comparable to burning up in a bus fire. Another option (cheaper too) is a spring loaded or automatic center punch like this
can be found all over the net for less than $5 and will take out a window without fear of slashing your hand or knocking your knife out of your hand sorry for the thread drift but seemed like a good ideal.
For me that wouldn't be practical to be carrying a dedicated tool for breaking glass like I'll be encountering that everyday. Too much crap to carry.
I'd be very interested in seeing different pens with glassbreakers. I really don't want to have to carry more crap and a pen is something I already carry.
If you can add one more thing to your EDC, then I'd suggest the Benchmade Houdini Pro.
As for a folder I can only think of the Gerber Hinderer Rescue or the Boker Magnum Paramedic/Fire dept./Law Enforcement Rescue series
All of the above made in China though.
