I started with a sharpmaker, should be called the sharpkeeper, trying to reprofile with a sm sucks, I got a kme to set my bevel and use the sm to maintain the edge, I got the universal stone holder for the kme that holds the sm rods, I can get a mirror finish and a hair whittling edge of the stones with that setup.
is that with the base?A guy is willing to sell me his kme with the gritomatic stone carrier for 100 only issue is the stones need replaced but u guess with the universal stone holder that opens up options on what stones to buy which is kinda nice
the kme diamond stones go for about $24 a piece, if you were to buy that system from him at $100, and new stones, that puts the price to about the same as a new one, $75 would be more reasonable, if you were planning on getting different stones for it, it may not be a bad way to go, hate to see you pay the price tag of a new system but have a used clamp.A guy is willing to sell me his kme with the gritomatic stone carrier for 100 only issue is the stones need replaced but u guess with the universal stone holder that opens up options on what stones to buy which is kinda nice
Yeah with Base and gritomatic universal stone holder for 100. He said the kme stones are worn out and probably need replaced. I thought for a 100 and thr extra stone carrier the price was ok with a base also but I also figured for 180 blade hq with gold stones and make my own base as a option toothe kme diamond stones go for about $24 a piece, if you were to buy that system from him at $100, and new stones, that puts the price to about the same as a new one, $75 would be more reasonable, if you were planning on getting different stones for it, it may not be a bad way to go, hate to see you pay the price tag of a new system but have a used clamp.
Eman816, IMO get that 100 buck deal. tonymp is using Jesse's 3D printed and assembled Universal stone holder, the one he provided tube for, it holds KME, Sharpmaker stones flat and edge up (3D holder has a special Sharpmaker shaped triangle hollowed out on each end. It also holds any Edgepro size stones. Gritomatic's Universal stone holder holds the same stones, but Sharpmaker stones lay flat against the holder, only giving you the corners for honing. I have used Congress Moldmaker 240 grit / 60 micron SIC on 4 knives with Jesse's 3D holder: 8Cr, VG10, N680, N690. Worked OK, and I could mount stones with 1 and a half hands. Because I was re-establishing edges and thus using appropriate pressure, I found that I had to mount stones with more spring tension, or else I would need to keep an eye on stones, and once in a while push them back down level in the holder.
Used Venev 60 (240 grit-felt finer then Moldmaker 60) as the next stone, mounted in Gritomatic's stone holder. I really like it. For me it was easier to mount stones by virtue of being larger. Also, it felt better in hand then KME holder, lighter, and better ergos with the wood ball shape. I also used KME 100 grit diamond with Gritomatc holder on s30v and felt like I had good control. I use generic window cleaner or wet water with all the stones.
Both holders could use a parking notch / magnet so spring side of stone holder would not spin. It would be less fiddly. Also I would like insight into choice made for both spring lengths, which are similarly sized. Seems too short a range. I think a tad more range would help me mount stones tightly.
Keep in mind I am modding the KME using KME's Axe sharpener along a DIY run of slide, so I can sharpen longer Kitchen knives, and still only use the one OEM clamp. With this mod 6 inch stones will be useful across their entire length.
240 grit - 60 μm via Congress’s Mark Froelick CS.
Venev bonded diamond stone 60grit=225μm from GRITOMATIC’s great table.
KME 100 grit ~163μm
KME customer service referenced micron- grit finder
https://www.bestsharpeningstones.co...article_name=MicrontoGritConversionCalculator
Eman816, I tweek explaination a bit. I tried to explain what both after market KME universal stone holders held: Sharpmaker rods, and 4 through 6 inch stones. The Gritomatic Stone holder works great for all the stones you're using now. You are correct in thinking the Gritomatic will let you add any of many different kinds of stones as your paychecks roll in, like the inexpensive SIC. Get your buddies KME. A C-note for everything you reported is a good deal.
If you could give more detail about what is not working now, that would help us help you. Who knows, maybe you don't need to spend more money to solve your sharpening problem/s right now, but could save up for a KME instead.
Hi,Hey guys so I was wondering if theres any improvement I could do to my knock off kme. Like to make it slightly better with keeping angles and everything or should I just scrap it and get a kme?
