- May 6, 2018
Serious question for info. Is that edge then used to baton through bone or why so wide angle ?
Mostly because these knives are no super steel and are not really serving their intended purpose.
I see. Thank you. I had not realized that was a common use case. How long and/or heavy are the knives you are describing? I've seen everything from a Buck 110 to a full-on Bowie called a hunting knife.
Axes at 21 machetes at 15...Wait for the razor at 3
I been using this as general guide for a long time.
Can someone provide me an explanation. As why I would want to sharpen my machete at 15 degrees. I understand why an axe could be sharpened under 35 no problem but a machete up to 15 seems... yishh.... stretching it. Normally I give the General use angle for these. and Hunting and camping knives falls in the general use also. I might be too old school but these values works perfectly for me.
That's 15° per side. So 30° included angle. It's more penetrating, which actually minimizes strain on the edge because the impact force is spread along a more gradual slope. So you get better performance with less effort and the durability is just fine. NO edge damage in use, even with heavy chopping use and it works better...can you provide an explanation for why you wouldn't want the edge at an angle that's still more than strong enough for its applications and has significantly increased performance?
Meanwhile, my scythe edges are 7-9° per side and can sever thumb-thick green saplings without taking damage. Using good technique does play a role in that, though.
I'd suggest giving it a try, with a quality machete. It's a cheap experiment, and I think you'll find the results illuminating. If you haven't used them that thin then I think you're missing an important piece of perspective when it comes to understanding "good" performance from a machete.![]()
NewBe here. I have been following this forum for a while and thought y'all could help me with a question. I am wide open to your comments and opinions.
I have been sharpening for fun and money for 50+ years and consider myself a good functional sharpener. I have a reasonable working understanding of the edge angle and the trade off between sharpness and life, and the other variables that affect overall performance. I can't determine the type of metal the knife is made from, other than carbon steel vs stainless steel, and it usually does not matter when I am sharpening. The owner just wants the knife sharpened.
I have always had a problem determining either the existing or newly sharpened edge angle. Hand me a knife, ask me the edge angle, and all I can do is make an educated guess. Can I be within +- 5%?, only with luck. To help me, I purchased the CATRA Laser Knife Edge Protractor, $300+, and now I can actually see the measurement of the edge angle. I believe it helps me sharpen better and to provide consistent results.
My question is:
Does, or would, being able to accurately read the edge angle, improve your ability to sharpen?
FortyTwoBlades Are the angles you are giving mechanically exact all the way to the apex? I have skepticism for "7-9° per side" for a scythe as that is similar to a straight razor, and those (razors) still benefit from micro convexity through stropping if I am recalling scienceofsharp correctly.
I have very little flat ground, most everything is on a slope, or undulating up or down...and with the variety of growth on the front and rear yards, I'm constantly shifting and readjusting.
Plus, I don't have the fanciest gear. I have an Austrian scythe set I picked up from Lee Valley some years ago. It gets the job done but it's my first rodeo with scythes. (I was an apartment dweller until I bought this home 15 years ago.)
Austrian blades are frustratingly soft to me. You'll find in videos of users of the continental European type that many of them use a lot of speed in the stroke to compensate for the dulling that occurs almost immediately with their edges. To keep them as keen as I insist on I have to hone after ever 6 strokes or so. Of the Euro-style blades out there I find the Russian ones to take and hold an edge the best. They're almost as hard as an Austrian-made American-pattern blade, though still a touch softer, and the Austrian-made American blades are soft compared to the historical norm. I'm actually working with Arti of Russia right now to get new American pattern blades made to my own specs. They just did the first experiments with forging an American-style cross section yesterday!![]()
