KornalskiKnives
- Sep 12, 2014
Hi,
You can find me on my website --> www.kornalski.com.pl
There are links to Instagram or Facebook if you use them.
Any questions; orders or want to talk mail me --> adam@kornalski.com
To all costs posted in the thread --> you need to add 5% for PayPal fee.
STEEL - AISI A8Mod (Bohler Chipper, Uddeholm Viking)
General Uddeholm Viking is a oil-air-vacuum-hardening steel which is characterized by: • good dimensional stability during heat treatment • good machinability and grindability • excellent combination of toughness and wear resistance • normal hardness in the range 52–58 HRC • ideal for surface coating (CVD, PVD) Exaggerated sketch of a typical punch and die in action. The chemical composition of Uddeholm Viking gives a hardness potential of 58 HRC with compressive strength and wear resistance accordingly. The small amount of primary carbides means a high chipping resistance and with 8 % chromium follows a very good hardenability and also a fairly good resistance to corrosion.
Typical
C Si Mn Cr Mo V analysis %
0.5 1.0 0.5 8.0 1.5 0.5
Applications Uddeholm Viking is a versatile, high alloyed tool steel characterized by the right combination of toughness and wear resistance required for heavy duty blanking and forming.
Knife: PushDagger
Steel: A8Mod Tool Steel
Thickness of 6,8 mm
Hardness: 57-58 HRC
Handle: G10 black sandblasted
Attachment: Turn black imbus screws
Finish blade: Stonewash
Size:
Total length: 180 mm
The width of the blade: 45 mm
Blade 105 mm
Weight 255 g.
Sheath: 1,5 mm black Kydex with Big TekLok
Asking: 200 $ shipped
Knife: KRYPTON170
Thickness of 6,8 mm
Hardness: 57-58 HRC
Handle: Brown canvas micarta sandblasted
Attachment: Turn black M5 imbus screws
Size:
Total length: 300 mm
The width of the blade: 38 mm
Blade 170 mm
Weight 465 g.
Sheath: 1,5 mm black Kydex with Big TEKLOK
Asking: SOLD
Knife: AgorEDC
Steel: Vanadis 4 Extra PM Stainless Tool Steel
Thickness of 4,7 mm
Hardness: 63 HRC Secondary hardness
Handle: G10 Black sandblasted
Attachment: Turn stainless steel M5 torx screws
Size:
Total length: 255 mm
The width of the blade: 33 mm
Blade 125 mm
Weight 219 g.
Knife I
Knife: Bushcraft
Steel: O1 Tool Steel
Thickness of 4 mm
Hardness: 60 HRC
Handle: G10 Orange + 1 mm yellow liners
Finish blade: Satin
Size:
Total length: 220 mm
The width of the blade: 30 mm
Blade 110 mm
Weight 180 g.
Asking: 150 USD Shipped
STEEL - AISI O2 (Bohler K720)
Oil hardening, dimensionally stable tool steel.
Tools (punches) and dies for blanking, punching and similar operations; threading and wood working tools, machine knives for the pulp, paper and metalworking industries; measuring tools and plastic moulding dies.
Chemical composition (average %)
C Si Mn Cr V
0,90 0,25 2,00 0,35 0,10
Obtainable hardness: 62 - 65 HRC
Knife: Agor
Steel: O2 Tool Steel
Thickness of 4,4 mm
Hardness: 60 HRC
Handle: Brown Micarta sandblasted
Size:
Total length: 265 mm
The width of the blade: 32 mm
Blade 140 mm
Weight 255 g.
Sheath: 1,5 mm black Kydex/ABS 2 mm with Big TekLok
Asking: 150 $ shipped
Agor I
Agor II
Knife: Mikko
Thickness of 4,4 mm
Hardness: 60 HRC
Size:
Blade 130 mm
Weight 255 g.
IMPORTANT NOTE:
Bohler Stainless Steel N690 tool steel is very good steel.
But when hard is not very tough for heavy works especially with the tip.
So:
No rust, holds working edge long, easy to sharpen but not suitable for tanks or windows opening. You can loose the tip.
Perfect for kitchen, cutting, slicing or skinning.
Please consider this when buying.
J.
Knife: Agor
Steel:N690 Bohler Stainless Tool Steel
Thickness of 4,4 mm
Hardness: 58 HRC Secondary hardness
Size:
The width of the blade: 34 mm
Blade 140 mm
Weight 245 g.
Sheath: 2 mm black ABS with Big Tek-Lok
Asking price: 150 $ shipped
Typical
Knife: PushDagger
Thickness of 6,8 mm
Hardness: 57-58 HRC
Size:
Blade 105 mm
Weight 255 g.
Knife: KRYPTON170
Thickness of 6,8 mm
Hardness: 57-58 HRC
Size:
Blade 170 mm
Weight 465 g.
Asking: SOLD
Knife: AgorEDC
Thickness of 4,7 mm
Size:
Blade 125 mm
Weight 219 g.
Knife I
Knife: Bushcraft
Thickness of 4 mm
Hardness: 60 HRC
Finish blade: Satin
Size:
Blade 110 mm
Weight 180 g.
C Si Mn Cr V
Knife: Agor
Thickness of 4,4 mm
Hardness: 60 HRC
Size:
Blade 140 mm
Weight 255 g.
Agor I
Agor II
Knife: Mikko
Thickness of 4,4 mm
Hardness: 60 HRC
Size:
Blade 130 mm
Weight 255 g.
IMPORTANT NOTE:
So:
J.
Knife: Agor
Thickness of 4,4 mm
Size:
Blade 140 mm
Weight 245 g.
