Koster Kloset Klean Out !
Feedback: +138 / =0 / -0
I'm trying to fund another project so My Koster need a new home.
Survivor
Specs:
Overall length = 16 inches
Blade
• 9 inches (sharpened), 10 inches to the front of the handle
• A2 steel, hardened to 59 HRc
• 1/4" thick
• 2.25" tall at the belly
• Flats will be "as-forged" finish
• "K" logo will be etched
Handle
• 6 inches (from front of the handle to the pommel)
• 5.5 inches of actual handle material
• 1/4" thick material (0.75" total)
• Green canvas micarta
• 2 lanyards/tie downs (front safety lanyard = 1/4", rear handle lanyard = 3/8")
• 2 Corby pins (mechanical fasteners)
Handle is large enough to fit an extra large hand "just right".
POB (Point of Balance) is "in the ring"
Ring is 1 inch diameter and will be chamfered inside/out
. Bushcraft 2008 Green micarta,2008 Green micarta
CPM 3V Steel
Aluminum Corby Bolts and Lanyard
Scandi grind set at 12.5 degrees, 120 grit finish, lightly stropped and SHARP!
1. 4" blade length - from tip to the front of the handle (aka "legal length")
2. Larger Handles (3/8" thick handle slabs)
3. Spine will be squared for striking a firesteel
4. Thumbgrooves will have a slight burr - also for using with a firesteel
5. Blade is ground as close to the guard as possible
Koster Bushmaster BCM
10 inches overall with a 3/16" thick, 5" long blade and a 5" long Black Micarta handle. O1 steel BCM scales
Kosters all Lightly used, normal scratches ,Bushmaster is lightly used and has light scratches from Kydex sheath.
Survivor & Bushcraft as a pair w/LH Leather Sheath (Firesteel NOT included) $395 CONUS Shipped (also have bushcraft kydex to go with)
Bushmaster $155 w/Kydex sheath shipped CONUS
Paypal or USPS M.O.
