You didn't specifically mention a price point so, based on your question I'll assume you are looking for quality at a relatively low price point.
I personally own and use some Henkel's Pro-S, Spyderco kitchen, George Tichbourne custom, Chicago Cutlery and, a handful of other strays acquired over time.
On the cheap end, I have found nothing better then the Spyderco line. In particular, their Santuko is a very versatile knife at a good pricepoint. It's thin profile and ergonomic handle with plenty of knuckle clearance will give you years of good service slicing vegtables, dicing ham, etc.
The Chicago Cutlery are good knives in a block set if you are willing to live a set that dulls very quickly. The hollow grind will make the knife wicked sharp for the first few cuts but, it quickly gets dull as a butter knife.
I really like my Henkels Pro-S chinese cleaver. It fits in the same role as the Spyderco mentioned above. It has a more traditional appearnce and gives the appearance of knife that costs significantly more then it really costs. This is a very traditional looking knife line.
While George Tichbourne is a custom maker, his prices compare very favorably with the German mass market lines (Heckels, Wustoff, etc.). These are true custom knives so, if you really know what you want, they will be tweaked to perfection. In my case, I got a larger handle that has a more squarish profile then standard. The red liners between the tang and the paper micarta were for eye appeal. Finally, I had a lanyard hole added for safety (these are very sharp knives after all so, dropping one could lead to serious injury to a a foot or toe).
I should also note that my Trace Rinalid TTKK in BG-42 sees most of its use in the kitchen. A 10 pound sack of potatoes can be sliced and diced without fatique and the knife will still be sharp enough to scare the hairs off your arm before the edge makes contact with them
At ~$200 I would get a K6 and K3 from George Tichbourne. The K3 I received had more of a "Moose Hunter" profile the K3 pictured on his website and it has worked out very well. Check them out at
http://www.tichbourneknives.com/kitchen-n.htm and tell Carol I said Hi!
At $120, the Tichbourne K6 gets the nod.
At $50, the Henkels Pro-S is a very good value and a versatile knife.
At ~$50 to $100 set, the Spyderco Santucko with the plain edge slicers are the way to go.
For an heirloom that will treasure (and used) by your great grandkids, and their great grandkids, get as much of Tichbourne set as you can afford!
