- Jun 24, 2013
Its so simple I thought a few of us might give it a try.
Only do it if you are sure you aren't electrocuting yourself or that sparks might fly and burn your house down.
I am just describing what worked for me and if you follow it then at your own risk.
Here is my Kukri Etching DIY tutorial with pictures.
Happy Thanksgiving.
1. Scotchtape the target area
2. Mark your outline with a Sharpie
3. Cut it out with an exacto knife
4. Peel of the cut sections with a forcep/tweezers
5. Etch using a DC source (12V car starter battery here)
Plus clamped on the blade
Minus clamped on a q-tip soaked in saltwater
should only take 1 minute for a similar size pattern
This will remove material wherever there is contact to the metal
6. If you wish to turn your etched pattern black use an AC source (12v door bell transformator here)
one contact clamped to the blade
the other one to a saltwater soaked q-tip
which contact where doesn't matter since its AC
7. remove all tape and rub the etched area in wet baking soda (toothbrush recommended) to keep it black and not turning into red rust
8. rub your blade with oil, dry it, apply some oil again
Typing this took longer than doing it.
Here is the result on my daughters Biltong.
A.V.S. are her initials. How to arrange them was her idea.
I hope she will like the surprise when she gets up in a few hours.
Feel free to comment with questions or suggestions for improvement.
Thank you.
Again, Happy Thanksgiving!
Happy Thanksgiving.
Thank you.
