Uncle Bill
Can you give us a update of your Kukri making process. Which part are hand made, which parts are machine made, and how long does it take to make one?
PS. Have you heard of something called case hardening? Your Kami's probably use that process already without knowing it. Basically, if you look at the shackle of a good pad lock, it probably has "case hardened" stamped on it. Basically, you want a tough shackle to be hammer resistant, but also a very hard shackle to be saw resistant. The solution is make the shackle out of low carbon steel, which remain ductile and tough after heat treatment. The shackel is heated inside a high carbon environment, where the carbon diffuses in the surface, changing it to high carbon steel. High carbon steel can turn very hard, but less tough when heat treated. When the shacke is quenched after heat treatment, the outer high carbon surface gets very hard, but the inner core is still very tough.
I heard some africans treat blades with animal leather and bones. That results in a hard nitrite surface. I don't know about that though.
Andrew
Andrew
