- Oct 2, 2015
Kind of unique hinged tail piece of a tang. A lot of fiddley extra, but alls well if you like it...
Goodluck getting its handle internally machined out. Will it be one solid piece?
If so, its needing substantial hollow space internal to allow your hinged piece entry, then turn the bend to exit at a pommelnut. You might consider alot of internal sloppiness. Then after threaded thru, fill its voids with epoxy before screwing on its pommel.
I think it willl be fine near its ricasso, just keep the beginnings of taper wide as possible & dont create stress risers where directions change.
Good luck getting that complex internal passageway machined out...
any suggestions on now to improve the design? This is the first time I've designed a knife
