- Aug 13, 2002
Thanks again for the good words guys.
Joe, I will probably make another thread since working on this one it is obvious to me now that I want one for myself.
Jonny, I am sorry to disappoint but I went with the more traditional pommel. I liked the other pommel but still can't quite see how to make it work visually and I want to keep the momentum going on this one.
Back to work.
Started on the threaded end. Shaped it roughly on the grinder and then finish rounding it out as best as I could with files. I will be using 1/4-28 for this.
Using a die and Rapid Tap I did an ok job of threading it. It is not quite as clean as I would like it so I may end up welding a threaded rod on instead but for now it will do.
Next we cut a a round recess for the retaining nut with a 3/8th endmill.
Don't know if you can see it but I left a little lip so that the retaining nut tightens against that.
Now it needs a temporary nut. Facing some scrap mild steel rod.
Center drilling. Always a good idea to use a center drill first.
And drilling the correct sized hole for 1/4-28 thread which is a no.3 drill
Now I use the lathe to align and engage the tap a little. *WARNING* Please note that the chuck is not turning. I am not doing this under power but turning by hand. All I want to do is get the tap started as straight as possible.
Remove the whole thing and finish it by hand in the vise.
Finally it all holds together. Just need to shorten the nut a bit.
More to come...
Back to work.
More to come...
