Got some repost and some price drops today. If you would like to purchase a knife you can post I'll take it in the thread. Paypal can be sent pandrewbures@yahoo.com. International shipping is available, PM for a quote.
I have these listed on other threads so I'm only going to post one picture for each item. If you want to see more pictures message me and I will send you more.
Up first are the Kwaikens
#1
Was SOLD shipped in the U.S.
This kwaiken is madefrom 1095 carbon steel. It has been heat treated to 59-60RC in hardness. The blade is ground with a right side hollow chisel and chisel. The handle is wrapped with black cotton cord and over wrapped with dark red paracord that was coated with resin. It comes with a leather cross draw sheath. The menuki is made from titanium.
8 3/4in long X 1in wide X 1/4in thick. Handle is 4in long.
#2
Was $175.00 Now $140.00 Shipped in the U.S.
This tanto is made from 1095 carbon steel and is ground with a right side chisel grind. The handle has leather panels with a leather arrow menuki. Its over wrapped with dark brown paracord that was soaked with resin. The resin made the paracord super dark. They were oil quenched then tempered to be 59-60RC in hardness. It comes with a leather cross draw sheath. 10in long X 3/16in thick X 1 1/4in wide. Handle length 4in
#3
Was SOLDShipped in the U.S.
made from 1095 carbon steel that has been heat treated to be 59-60RC in hardness. The blade is ground with a double right side chisel grind. It is sharp on top and bottom. The handle has leather panels that is over wrapped with black paracord. The menuki is made from titanium. It comes with a leather cross draw sheath.
9 3/8in long X 3/16in thick X 1in wide. Handle is 4 1/2in long.
Pocket Tantos:
#1
Price:SOLD Shipped in the U.S.
This tanto is made fromD2 tool steel. It was plate quenched then cryo quenched and tempered to be 59-60RC. The blade is ground with a right side chisel grind and the handle is wrapped with black cotton cord that was soaked with resin. Comes with a leather pocket sheath. 5 1/8in long X 3/16in thick X 1 3/8in wide. Cutting Edge 2 5/8in long.
#2
4 1/2in long X 3/16in thick X 1 1/4in wide at widest.
Was $50.00 Now $40.00 each Shipped in the U.S.
Both are made from 1095 carbon steel and heat treated to be 59-60RC. Both are ground with a right side chisel grind. Both are wrapped with black paracord that was soaked with resin. One comes with a leather pocket/belt sheath and the other comes with a leather pocket sheath.
#3
4 5/8in long X 3/16in thick X 1 1/4in wide at widest.
Utility Blade Was $50.00 Now SOLDShipped in the U.S.
Made from AEB-L stainless steel. It was plate quenched then cryo quenched and heat treated to be 59-60RC. The blade is ground with a right side chisel grind and a left side back bevel, the end is sharp and can be used to push cut with. The handle has nonslip grip tape under a dark red paracord wrap that was soaked with resin. Comes with a leather cross draw sheath.
5 1/2in long X 1/8in thick X 7/8in wide. Cutting edge 1 1/2in long.
Black Kiridashi SOLD shipped in the U.S.
This kiridashi is made from 15N20 carbon steel. The blade is ground with a right side chisel grind. The handle is wrapped with black paracord that was soaked in resin. It comes with a black leather pocket sheath.
4 7/8in long
3/32in thick
1in wide
Cutting Edge: 2 3/8in long
Blade Finish: Cold Blued
#1
#2
#3
Pocket Tantos:
#1
#2
4 1/2in long X 3/16in thick X 1 1/4in wide at widest.Was $50.00 Now $40.00 each Shipped in the U.S.
#3
4 5/8in long X 3/16in thick X 1 1/4in wide at widest.Utility Blade Was $50.00 Now SOLDShipped in the U.S.
4 7/8in long
3/32in thick
1in wide
