Kydex sheath with "frog-stud"
Nice job, Horus!!! As Normark stated, I've been doing this style of sheath for a bunch of years for any of the big blades, not just the Bagwell type Bowies. It's an old time carry, and I quite frankly don't know why you don't see more of it, 'cause it works very well for carrying a large blade concealed. With a big knife, there is no need for straps, cord chain, etc. as long as the tension/release is set right, but that's the trick in doing one. With smaller blades (5" blade and below), you will be better off with an IWB loop of some sort (chain or cord included, as well as "G" clips) - this has to do with the blade to handle length ratio. I've done a few with 5" blades, but feel more comfortable with 6" as the lower cut-off limit of practicality for the stud alone to work. If the handle is longer than the blade, the unit will tend to shift more with movement, as well as being a little top heavy and wanting to pull out from the body instead of hugging it - that's why you need some sort of anchor for the sheath. The longer blades allow belt pressure to keep the unit snug to the body without shifting, and if tensioned properly, the knife will release from the sheath with ease. If concealment isn't an issue, just shove the sheath behind the belt at whatever angle, and the stud prevents it from falling below belt level. Extremely versatile form of carry.
Hey Mike.....
Ahh drew you out of the woodwork.. Like a viet cong into an ambush..:)
I'm a little disappointed ytou didn't reply to my poke at you though... LOL:)
Hows it going my dusty black, friend ??
Hope all is well and you had a good holidaZe...
Looking forward to seeing you at Wolverine..
ttyle
Eric..
Here are the mpegs:
Please use the Real Player and copy the following adresses into the "open adress“-field.
The "effect“ ...
http://toms-cursor-page.de/Flip.mpeg
and the use.
http://toms-cursor-page.de/Ziehen2.mpeg
Mike,
thanks for your nice comment and the interesting information about the weightbalance-aspect.
I think you will understand, that I do not want to give up the easy use of the the frog-stud without necessisty. So I will test to carry the sheath without any fixing. If it shows problems (I hope not) I fix the sheath with the static line-method.
