Hello,
There is also the Blade protection Factor, both Kydex and Consealex offer this.
it also is a great material on a big knife for if your Clumsy like i am and fall down alot in the woods,to Protect your Lower Limbs from suddenly becoming Punctured, when your knife pokes its Tip through the Leather.
(ouch)!! Its also good because it doesnt need
any external Treatments, bees wax,, neatfoot oil,,Ect,,ect, to Protect the material and to keep it supple.
it also is much more Cost effective to the protection it offer`s, to construct than anything else.
it has no Absorbancy Rate so you dont have to Walk around carrying you Knife, while your leather , or Wood sheath Dries out.
It also can Be washed and Drip dried or Blown out when it becomes dirty, Even in the field no less!!
The material is More Cost effective to the benifits gained.
You dont have to buy expensive Stitching Equipment to use it, or waste money having somone else sew them.
You can paint Happy Daiseys or Smiley Faces on Kydex with Testors Model paint if you wish to Add ART..........LMFAO
Or even Glu Various grades of Varmit skins or Reptile skins to Kydex if you really want to
(although i find this silly) i mean isnt that why you use kydex in the first place, to not use said Glued on materials.
you Can Even use KYDEX/ Consealex Sheath bodys as SPlints in the field for Broken body parts(Depending on sheath size of course).
I also use my kydex/consealex sheath`s(because i form them this way) as Training Aids, by taking of the screw post attached Belt loop and since it is a Snap on retention, use the Body of the Sheath as a protective blade covering, so i can use my live blade and the handle i am use to Grabbing, in Knife Offence and defensive drills,without having to waste money on a trainer knife(what a concept)!!
its also quite Un-noisy in the woodline ,,or should i say it will be when i get my little experiment done im working on(stay tuned)!! and no im not going to Glu anything to it....Lmao
its also leaps and Bounds more Resistant to Chemicals, solvents, acids,,, bacterial, Viral, and other Agents than anything else is. Consealex excluded as it exibits the same Resistance.
It also is Multi enviromental in its applications, from Diving to Jungle to Desert, to humid, to extreme cold climates.
and on and on and on!!!
my opinion only of course,
Merry Xmas,
Allen blade
