- Oct 22, 2007
Can anyone share their heat treat formula's for L6?
I have heat treated smaller blades with good results but I just finished up a 3/16" thick X 8" (approx. length including full tang). I took the blade to 1475 degrees and soaked for 10 minutes. I quenched in transmission fluid. I cleaned off the blade and tempered at 400 degrees twice for one hour each.
I don't have a way to test the RC hardness but when I run a file over the edge (triangle shaped file, using the corner to bite the blade) it bites in rather than skating over the steel. When I heat treat D2, 440C, ATS34/154CM the file skates accross the steel.
Help??
SDS
Help??
SDS
