- Jul 27, 2003
Anyone here have successful L6 heat treating "recipes" they would like to share?
No.... L6 and I don't get along. I hope you have better success with it than I did.
But here's Crucible's data sheet, to get you started:
http://www.crucibleservice.com/eselector/prodbyapp/tooldie/champloy.html
If one is normalizing for the effects that industry often cites - softening, stress relieving and making pearlite then many alloys we work with need not be normalized. However if you are hoping for evenly distributing carbon and other constituents, evening out stresses, grain refinement and generally fixing much of the havoc you inflicted in the forging, then normalizing is very useful with L6 and many others. You just need to remember that pearlite will not be part of that process. Evenly heating to a proper temperature and then allowing things to cool evenly will do wonders for any simple alloys even if it does not soften it, but then softening is what annealing is for. Unlike 1075, L6 will not recrystalize properly at around 1000F because it will not make pearlite, you will need to cool to around 750F and allow upper bainite to do that same job. For grain refinement the air hardening tendencies actually work in your favor. The hardened steel will have a higher amount of stored energy and will recrystalize faster and finer than soft steel.
To all of this I would add that I have found normalizing to be come even more important with deep hardening alloys due to dangers of cracking and distortion due to cooling from an enlarged or uneven grain condition.
The chemical you can get any place that sells pool or hot tub supplies. As for the steel, you can send it any time but it could be quite a while before I could get to it for analysis, the metallography takes enormous ammounts of time in polishing and I have a back up of people I was to help out in this regard.
Kevin, would this apply to 15n20 also, as it's similar in composition to L6? I've been playing with 15n20 and even after a couple normalizing cycles it's still almost too tough to file. Is the lack of pearlite a bad thing??
Sometimes it's hard to wade thru the available information and decide what is fact, opinion, or just plain clueless babble. We're very fortunate to have guys around here that will step up and state 'what IS and what is NOT'. Your time and efforts are GREATLY appreciated!!
