Laci Szabo daggers
CapitalizedLiving
Basic Member
Feedback: +215 / =0 / -0
The following knives were designed by Laci Szabo and handmade by Robert Newton in the USA.
From left to right: the Finger Rocket, Ace of War, and Spade of Mars
Finger Rocket
The Finger Rocket is designed as a super compact defensive weapon built for discrete carry, maximum retention and with the cutting ability of a larger weapon. It is cut from 3/8" thick ATS34 steel with a bead-blasted finish. The over finger ring (1 5/8" x 1 1/8" diameter) and tab cut reduce weight significantly while retaining a balance behind the blade for fluid handling. The 2" double-edged blade features a very slight hollow grind with flat secondary bevels.
Comes with a kydex sheath and belt loop attachment. Never used or carried, but there are a few light marks on the blade from the sheath. I paid $125 for this.
My price is $75 shipped in the US, Paypal included.
Ace of War
The Ace of War is another compact dagger designed for discrete carry, maximum retention and with the cutting ability of a larger weapon. This is cut from 3/8" thick 5160 spring steel with a blued finish. It is 5.25" long overall with a 3" flat-ground, double-edged blade. The long stems make this far more stable than most push dagger designs, and the wide blade makes it as effective at slashing as at piercing.
Comes with a kydex sheath and belt loop attachment. Never used or carried, but there may be a few light marks on the blade from the sheath. I paid $125 for this.
Spade of Mars
The Spade of Mars is essentially a Finger Rocket on steroids. It is cut from 1/4" thick 5160 spring steel with blued finish, and features an oval finger hole (1 5/8" x 1 1/8" diameter) and seven round holes for lightening and aesthetic. It is 7.25" long overall, with a flat-ground 4.25" double-edged blade. It's just plain nasty.
Comes with a kydex sheath with belt loop attachment. I used this once on some grape leaves to see how it handled. It has some scuffs from the kydex and a couple stain spots from handling. Otherwise it is new, the edge is perfect. I paid $325 for this. Only three were ever made.
My price is $125 shipped in the US, Paypal included.
Buy the Ace of War and Finger Rocket together for $200 and you'll get this Cat Claw also. This is less than half my cost!
Cut from 1/8" thick 5160 spring steel with blued finish and beveled for comfortable edges. The ring has a 1.125" diameter. The blade has a 2" front edge and 2.5" back edge. Overall length is roughly 4". Comes with a simple kydex sheath with a lanyard hole for neck or pocket carry.
Never used or carried. I am the original owner. It has been stored in a case to prevent wear.
I received these the other day in the mail, great deal and a smooth transaction! Thank you!
