TLR
- Oct 5, 1998
So I had a knife that has been sitting waiting on me to make a sheath and finish up the edge. When I pulled it out I realized that the scale on one side had lifted away from the metal back to the first pin. Obviously there was an issue with my glue up as it should have held regardless. I was using G-flex epoxy by the way.
My primary question is why the scale curled to begin with. It was a laminate of black micarta and a blue g10 liner. When I first glued them together there was a significant 1/8" curl in the whole sheet. I figured I would remedy this by simply sanding down the sheet flat but I still don't understand why it curled or why it is continuing to curl. The g10 and micarta are both from big name suppliers. Thoughts?
