- Aug 30, 2008
Thanks in advance.
This is my first attempt to make a handle for a knife using G-10 liners under Maple scales. (BTW, I'm an amateur hobbyist and this is my 3rd or 4th handle.)
As you can see I got no adhesion with the G-10, and the liners just pulled off the scales.
Here's what I did:
-- cleaned the Maple and G-10 with rubbing alcohol.
-- lightly sanded both G-10 and Maple surfaces with 100 grit sandpaper
-- re-cleaned both G-10 and Maple surfaces with rubbing alcohol (70% Ethanol, 30% water)
-- wiped surfaces dry and allowed to dry for a few minutes
-- mixed up my epoxy and applied to wood in a thin layer
-- laid G-10 liners on and worked 'em 'into' the wood
-- clamped liners to scales with Pony clamp
-- let sit at 61º overnight (18 hours)
What I see:
-- wood is well covered with epoxy in thin even layer of epoxy. There is even a slight impression of the light texture of the G-10 in the surface of the epoxy/wood.
-- there appears to be no epoxy adherent to the G-10
-- there is even and uniform (relatively) squeeze-out of epoxy along the edge of the wood.
-- epoxy is dried and very hard (a dried drop on the edge deforms slightly when struck with the back of a knife).
This is my first time working with G-10 and I just assumed that epoxy would stick to it like....glue.
Where'd I go wrong?
Here's what I did:
What I see:
