Here I have two of the newest AR15 Magazines from Lancer. The Lancer L5 Advanced War Fighter. These are the best out there in my opinion. The magazines are a combo polymer body with the one-piece steel feed lip. These are both 30 round, Translucent Smoke so you can see the ammo in them. Get the pair for $65 shipped in the USA. Paypal ('gift' or add 4%) or a money order will work.
Here is the factory product info on the mags:
The Lancer Systems L5AWM Magazine is a polymer and steel hybrid that combines the best features of each material. The one-piece steel feed lip unit is permanently fixed to the polymer body. The steel is hardened so the dimensions will not change in long term storage or rough use. The PTFE coating ensures the steel will not rust. The polymer body is designed with an internal dimension that is a constant curve, combined with a no-tilt follower for maximum reliability in feeding 5.56x45mm NATO ammunition. The exterior texture of the polymer body is aggressive for improved grip when changing magazines. The steel feed lip assembly and the polymer body are corrosion and chemical resistant. The translucent smoke body allows you to see how many rounds are remaining in the magazine. The Floor plate slides off similar to a USGI magazine for cleaning and maintenance. Weight is 4.4 Ounces empty.
Here is a factory photo:
