Originally posted by dylan_d
What would you guys recommend to someone who isn't very good at sharpening(me)? ...
Hey, guess what, they carry the Sharpmaker 204 at Bass Pro, at least the one in Concord, NC, where I got mine.Originally posted by dylan_d
And hell, I'll probaly run down to the bass pro shop and pick up a Lansky when I need to use one.
Actually the Sharpmaker angle needs to be just a bit more than the actual angle of the knife. If it is less, then you would only be back beveling, or removing metal from the shoulder of the bevel. If the angle is a bit more than the edge angle, then you are removing metal only from the very edge. It is even more difficult if the knife is exactly the same angle as the sharpmaker because the sharpmaker is rather slow, and if you had to remove metal along the entire edge bevel, as opposed to just on the edge, it would take forever. That is when they recommend back bevelling, so you can speed things up by only removing metal from the very edge itself.Originally posted by Andrew
but as long as the Sharpmaker angle is less than the angle on the blade, they do not have to match exactly.
