- Apr 12, 2009
Iv noticed that theres is a small amount of play when using a lansky causing It to give somewhat of a convex edge that may not be noticable to the eye. Once you finish with a coarse stone and have worked up a burr and it looks like you have hit the full bevel, you may have hit certain spots at slightly different angles or pressures leaving some spots more rough than others even though you cant see or even feel it. Every thing looks and feels great until you get to the yellow stone where the mirror polish shows up. Then it brings out the imperfections and shows scratches while other parts of the blade end up polished. What I do is starting with the most coarse stone work up a really good burr. This stone cuts the most but this is where the most material needs to be removed so itll take the longest. So work up a burr on one side, clean your stone and re oil it and gl over the same side lightly to take out any of the deeper scratches from the pressure. Then flip over and do the same. And so on until your finished with all the stones. It might not come out perfect but itll be a lot better. Iv had a lot of sharp ass knives from the lansky. All mine are users so a few scratches on a mirror polish doesnt bother me.
You might check your yellow (UF 1000) ceramic hone to see if it's flat. I noticed a similar issue with mine, and it turned out to be a little bit warped/bowed. Also noticed a similar issue with the Fine 600 ceramic hone (red/purple ceramic in the blue holder). That curvature in the surface of the hone will create some variation in angle, as the hone sweeps across the edge. I lapped both of mine flat, using a diamond hone, and didn't have any issues after that. It may be simpler to replace the hone (should be a warranty issue anyway), but flattening fixed the issue with mine.
David
