lansky questions
Greetings,
I am thinking about buying a lansky clamp sharpener for reprofiling, but I have a few questions.
1. Can I use it to sharpen the large and small blades of an sak?
2. What about a spyderco jester?
3. It seems like the clamp might be insecure on full flat grind knives. Is this the case?
4. Can I use the stones without oil like any other ceramic stones?
Thanks
I find the lansky I have good for small blades.For large blades you'll have to move clamp or you will change angles. It will make a knife real sharp but it will take some time for longer blades. I have been looking at the edge pro system.It's alittle more money but it looks faster.Hope this helps......Bigfish
Yes
I don’t know my guess is yes.
No, it clamps very well on flat grinds.
Sure, they work fine dry.
Thanks
Your welcome
I sharpen everything from my 1/4" tracker to my Sak on my lansky and can get both razor sharp.try different angles and stone combos for the best results.
It will work on a Jester. On full flat grinds, after you clamp up, check to see if the blade moves in the clamp. I try to clamp on a flat spot if there is one. The only knife I had a real problem with was a Buck/Mayo TNT with a full hollow grind.I would suggest you go for the diamond set. The stones will stay flat and give better results.
