For a complete beginner it is a great system to get a consistent edge and it's good for reprofiling the edge as well. But as mentioned, if none of the setting match the angle you'll have to reprofile the edge especially if the angles are different on each side, if you don't mind that and want an exact angle on your knives then it's good.
I've found that it's not good for blades over 4 inches or so and even 4 inches is stretching the limits a little bit. Anything under that is fine. Really aggressive and small recurves cause problems (for example Spyderco Cricket) but those could be sharpened with the hone meant for serrations.
There are a few trick to it as mentioned by wongKI:
A few things to note with the Lansky:
1. Stick some leather, felt or other soft material to the clamp jaws to prevent scratching.
2. Make a mental note of where you clamp the blade. For me, it's always about an inch down from the Spyderco logo.
3. First use is going to be a complete, time-consuming reprofile. Use the lowest angle.
4. It does get your knives sharp, especially if you have the finest (yellow holder/white stone, or Super Sapphire) hone.
1. Painters tape is the best for this IMO and you can find it in every house.
2. I made some measurements and calculations with the angles and made a handy guide for myself on how to get an EXACT angle:
First of all the numbers on the clamp are total BS, anyone with skills in trigonometry can verify this themselves.
This is how to get a real angle:
25 degrees (per side): Use the 30 degree setting with the edge 1cm (0.4") away from the clamp.
20 degrees: Use the 25 degree setting with the edge 1cm away from the clamp.
15 degrees: Use the 20 degree setting with the edge 2,5cm (1") away from the edge.
Getting the exact angle is crucial expecially if you are switching from system to system. For example if you use the Lansky to reprofile and sharpen real dull edges and a Spyderco Sharpmaker or a Lansky CrockStick set to maintain an edge.
And I do agree it is troublesome and slow to set up and it's not for sharpening on the go.
Lansky is good for reprofiling and and sharpening really dull edges.
The Sharpmaker on the other hand is much faster to set up and use, so it's best if you touch up your edges often.
